motor pulley for belt
dryer drum would not turn
belt broken but the pulley at the end of te motor was cracked into 2 pcs whic is what broke the belt. im trying to order that pulley and cannot identify it help
— Begin quote from TITANICHISPANIC;646721
aby body help
I do not work for AppliancePartsPros so it is probably best to double check this.
Anyway I looked at the parts for this unit.
Here is that parts breakdown.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=pygt244aww
There was no motor pulley listed.
I then clicked on the motor (Item 1 in Section 5), a new page opens with more views and a Q&A section.
The last question in that section was about the pulley and had the following info for a pulley part number.
AP4038987
With luck this is for your machine though I do not see how it is held onto the motor shaft.
