Hi,
I believe my problem is a broken belt but I can not find out how to open up the dryer. As you can probably tell by the model number but this is a dryer mounted on top of a washer.
All help is appreciated.
Thank you
Hi,
Thank you
Hi Chaz
I am not familiar with that model, and I assume no one else who responds on this Forum is either since they have not responded.
I can tell you that in general a dryer is accessed from the front, with the top and the front coming off. You can now install the belt, with access to the tension pulley from the front or from a panel in the back.
Good luck, hope this helps
