Iordered new motor switch part #777971 was shipped part #780164 which is new replacement switch the switch is different than original the problem I have is the white wire it says to hookup white wire from motor and white wire from harness the unit only has 1 white wire also new switch has blue jumper wire is it ok to move this wire to lower part of terminal as blue wire from harness has larger terminal and wiil not connect to lower end
Related topics
Whirlpool compactor Switch Complications | 1 | 5109 | December 15, 2012 | |
switch assembly whirpool GX900QPPB | 2 | 2601 | March 19, 2008 | |
SXC300W2 - Whirlpool Trash Compactor | 0 | 1510 | August 25, 2008 | |
motor switch | 0 | 2518 | November 24, 2007 | |
rewiring new motor to old wiring harness | 5 | 2164 | June 14, 2011 |
