Motor won't run
The motor wold only run for about 1 to 2 seconds then shutoff for 1 minuet. It continues this pattern several times then totally turns off. I ran the automatic function test and code says Motor-low current. I talked to 2 local repair companies and both said bad motor. I ordered a new motor (from APP) and installed. Same problem exists. Either both motors are bad (not likely) or that was not the problem. Machine fills, all cycles do the same thing. Serial #15325749YF if that helps.What test do you suggest now?
