Motor Won't Start
Fills With Water, Then Nothing But The Clicking Of The Timer And A Hum From Down In The Washer
Sounds like the hum is your motor trying to start … It could possiblly be jammed up with a sock in the pump. Iv seen that more times than not.
I Was Able To Turn (by Hand) The Center Shaft Of The Motor, But Will Check That When Owner Returns Home, Thanks.
I completely agree, sometimes a sock will get jammed in the water pump so definitely check that because that would be the best outcome
