hi my washer is spin mode the agitator is making noise
when it is in spin mode i can lift it up by my hands and it gos
quite can someone give me some info please
thank you very much
monterey:cool:
thank you very much
monterey:cool:
There is a bolt which holds agitator down. This could be the problem, or it could be with the drive block which is underneath the agitator (or it could be something else entirely, hard to say without being there which is what makes a problem like yours difficult to diagnose on a Forum)
Take out the agitator and check out the bolt. Change the dogs, or cams while you are at it and see if that does not fix things.
Good luck.
hi ok when my washer go’s in to spin mode. the agitator is trying to stop.
that is when it is making a load bang.can you help me.other then that
washer work’s fine
thank you. monterey
