My Frigidaire Professional Series is showing CL code
My Frigidaire Professional Series is showing CL code and I already took a few parts apart because I saw that somethings were off (not right).
So, this is what I have done so far:
  1. I took the inlet valve off the dishwasher and tested its electrical current and that was fine the current is there in the actual inlet but the electricity coming from the actual dishwasher is not there so its showing 0.
  2. Next, since I really had nothing to do I took the float switch off and looked at it but nothing was wrong there.
The reason I did these steps is because of the CL code and then also because I noticed that the dishwasher would show the code but the motor would still work. And although the motor is running no water is being pumped inside the dishwasher. I hope this is enough detail to help figure my problem out. Please let me know what you’ve got. Thanks in advance. :slight_smile:
