my portable washer is gushing water out of the bottom...
[B]When my Kenmore portable washer, model 110.49722990 is draining and and starts spinning, water gushes out of the bottom. However, when I have it drain only or spin only, it does not leak.
Any suggestions?
[/B]
So I looked at taking the panels off, but there were a lot of pieces that appear to be fixed, so I started looking at the attachments first.
What I found was a bobby pin had gotten stuck in the return hose and had caused a partial clog so all the water could not get out and was pushing out the other end of the hose only when draining and spinning.
I have removed the clog and everything is good far! I hope it was as easy at that!
Thanks Gene, for taking the time to respond to my problem!
Cheers!
I’m glad you were able to fix it.
I can get water into my machine but when the rinse cycle comes on, no water will enter the machine. I am good at repairs if I know what part to replace. I need a little help.
Thanks, Scott
The cold does not work but the warm does work. Is it the tempeture control assembly?
Scott
No. It’s the water valve.
