Nat-gas To Lp Conversion
:confused:A QUESTION TO ANYONE THAT KNOW THE CORRECT ANSWER…
WHEN A NAT-GAS DRYER IS CONVERTED TO LP GAS THE ORIFICE BECOMES SMALLER? CORRECT? SO, A PERSON USING THE LP GAS WOULDN’T FIND THEM SELVES IN A FIRE BALL OF WET LAUNDRY. NOW SAY THIS PERSON RETURNED TO CIVILIZATION, WHERE THE NAT-GAS WAS PLENTIFUL AND AVAILABLE. WOULD THIS PERSON HAVE TO RE-CONVERT THAT UNIT TO USE THE NAT-GAS AGAIN OR COULD THEY ACTUALLY USE THE NAT-GAS WITH THE LP CONVERTER IN PLACE? :pI KNOW IT’S ALWAYS BEST TO USE THE CORRECT PARTS FOR THE APPLICATION AND IN NO WAY AM I PLANNING ON…:eek:"AFRO-TECH-ING" THE MACHINE. BUT, I WAS TOLD BY SOMEONE THAT I SHOULD JUST BE ABLE TO FIRE IT UP WITH NAT-GAS…LIKE IT NEVER LEFT IT.- THANKS, IN ADVANCE FOR YOUR TIME.
