Need help, dishwasher won't drain
Good morning,
I need help please. I bought a Bisch dishwasher from a used place and it runs all cycles but won’t drain out the water. I have taken the filter out and even taken those 2 screws out and checked the pump, when I try to push on the propellors of the pump, they spring back. There is nothing trapped in them. I took the left panel cover off and I saw nothing wrong that I could tell. Do you think I need a new drain pump? What part should I replace?
THANKS!
— Begin quote from tommyadt;66613
Good morning,
THANKS!
You should be able to hear the drain pump run, if it gets power and is not jammed. My Bosch has markings for pressing two buttons to cancel washing and drain the water. If you do not hear the drain pump run, check for voltage across its electric connections. It there is voltage, then either the motor is jammed or has an open circuit.
