Need help to repair washer.
I need to replace the pump on the washer and cannot figure out how to remove the front of the washer.
Using a putty knife, insert about 2"-3" from each side of front of washer, between top and front panel. Push in with putty knife while lifting up on top deck. Done. May have screws on either side to remove after lifting top to allow removal of front panel.
