Timer counts down on all cycles but does not go to the off position, will continue to run until manually turning knob to off position.
Replaced timer switch but is still happening.
— Begin quote from Gene;32003
…When you said "timer switch" you meant the timer or something else?..
I need you to answer this question too.
