Need help with ge fridge
okay from the beginning i lost power in the living room, thought it was from the tv or something else, i turned the power back on from outside then after awhile my wife said she heard a funny noise from the fridge, the freezer then started to defrost everything, i looked up some forums and i located the mainboard there was a burned solder joint so i resolder it with a wire to jump from one point to the other. freezer still doesnt work, frost build up on the lower back pannel i took the panel off and used a hair dryer i also noticed that the fan does not move even if i push the button to trick the fridge in being closed. Now do i still have a problem with the main board, do i need a defroster and termister
or do i need a fan
im lsot
