need help with maytag dryer
ok well heres my problem. i wasnt gettin any heat from my dryer so i put a new igniter on and it worked for a little bit but now when i turn it on it will light for about 30 seconds then shut off but i can turn the gas down to it and it will stay lit for a minute or so. so what do i need to fix it. the dryer is a maytag model number LDG9206AAE
check for a plugged vent they will cycle on hi limit and do that or check the gas valve coils
i would try the used ones cant hurt
Don’t give up on the coils until you have checked it AFTER you restore your gas setting to its original state.
my whirpool dryer has low heat takes to long to dry clothes
— Begin quote from burl cooper;108243
have checked dryer vent and it is ok
