Hello all,
About a month ago my ice cube maker stopped producing ice. I immediately purchased a new water filter thinking that it may be the problem but it was not. I took the recommendation of a sales person at Lowe’s and took it out, let it thaw, and put it back in. That seemed to do the trick as the teeth started moving and water came down into the cube trays, and by next morning it made a row of ice. Well that was the last time it made any ice, and since then I have taken the maker back out again (on numerous occasions) and replaced the filter one more time. On top of all of this, the teeth still turn. Every day, I open up the freezer, press the button, and watch the teeth go through the motions but no water gets dispensed into the cub trays. Does any one have any idea as to what is going on?
