My Refrigerator Side Does Not Get Cold But The Freezer Side Does Is There A Reset Button For The Compressor Or Some Type Of Start Up Relay I Need To Reset
Cold air enters the fridge through a damper or vent between the freezer and fridge. The evaporator fan in or behind the freezer blows the air through. There is an adjustment to open and close this vent to allow more or less cold air in. Here is a diagram of the controls of your fridge. http://www.appliancepartspros.com/sect/b/e/r/ber79xcxi6.gif
yes i no and i have messed with it and it doesnt seem to be coming through its a real faint blow i not sure could a fan be broken
thank you for your help i have another question we got this frig… last night from a friend i plugged it in today around 2pm and i put the themp… for the freezer on 7 (1-9) and the frig on 8 the temp in the frig… is now in the 40s is it broke i guess im wondering if its suppose to blowout of not so faint do you still think it would be the defrost still or a fan or is it ok and just takes a while to cool down its a side by side ??? thank you again for your help
