I have change the heat element i change the float scwith.The dishwasher washs the dishes it just does not dry.The water temp is hot
You may have an open thermostat. AP2109201
It’ #29 in this parts diagram. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5151554&diagram_id=1243209#d1243209
— Begin quote from magician59;204481
You may have an open thermostat. [part]AP2109201[/part]
It’ #29 in this parts diagram. Tub replacement parts for FRIGIDAIRE FDB1050REB0 Frigidaire/dishwasher | AppliancePartsPros.com
Thanks i will try that next
