need help
my dryer stoped working i washed 4 loads and when i went to dry the last load my dryer was dead didnt do anything i put a new timer and heat element in around a month ago when i try and start the dryer its like its not pluged in?
Hi,
I would check the thermal fuse for continuity with a multimeter.
You may also want to check the door switch.
