A helpful relative found the leak coming from the solenoid water valve, WR57X10026.
He carefully marked the old valve, and the hoses, and then CUT THE HOSES ABOVE
THE MARKINGS! I need a schematic of the hose connections so we can install the
replacement part with the right connections. A physical picture of the valve showing which hose goes from which port to what would really be a big help!
Thanx! --doug
Here is the part.
If you click on the picture a new page will open with a Q&A section that has info on how to hook it up.
AP2071738
