Need tips on replacing the icemaker auger!
The plastic blade on the auger in the icemaker started cracking, so I ordered a new auger from you. We just received our replacement auger ([SIZE=2]AP3672963) and I began taking the icemaker apart so that I could replace the cracked auger. I can’t get the stupid thing out!! Any tips on how to replace it?
[/SIZE]
Hi Laurel,
In order to provide the most accurate advise I need the complete model number of the fridge.
[LEFT]Turn over the ice bucket and ice dispenser cover. Remove the Phillips screw.[/LEFT]
[LEFT]Remove the cover.[/LEFT]
[LEFT]Remove the Phillips screw for the ice cube control linkage and slide the linkage to the rear of the ice bucket.[/LEFT]
[LEFT]Using a pair of pliers, break the tabs off the back cover.[/LEFT]
[LEFT]Using 2 flat blade screwdrivers, disengage the locking tabs at either side of the ice crusher and remove the assembly[/LEFT]
[LEFT]Slide the back cover off the auger. The back cover must be replaced because of tabs broken off for disassembly.[/LEFT]
[LEFT]With a flat-head screwdriver, remove the C-clip from the end of the auger.[/LEFT]
[LEFT]Remove the auger and ice crusher blade assembly.
Gene.[/LEFT]
Thank you, I really appreciate that!
