Need replace the agitator and clutch. Was able to remove agitator and got that fixed. Then tried to remove clutch and gear shaft but shaft will not slide out of the tub??? Any sugesstions. It seems stuck inside the ring at the bottom of the tub. Any suggestions would be much appreciated. 2 teenage boys laundry is taking over home!! Thanks
Agitator must be removed first. Remove clip and plastic agitator drive from agitator shaft if it has one. Thoroughly clean exposed part of agitator shaft inside tub before removing gearcase.
Eric
โ Begin quote from fairbank56;794377
Eric
โ End quote
I removed the agitator. Next removed pump and motor from bottom. removed 3 bolts tried to slide transmission and gear shaft out I get it out about 4 inchs but it stops and wont go in or out. Watched your video thought I had the retaining clip and plastic piece but no donโt have that sprayed it with wd40 cleaned up the gunk off where shaft goes up through tub but still it wonโt move Could I not be strong enough to pull out?
โ Begin quote from mpritchardmk;794381
โ End quote
Can I send a picture of what the washer looks like?
โ Begin quote from mpritchardmk;794385
โ End quote
I attached the pictures of what the washing machine looks like right now. Hoping someone can help:)
All I can suggest is to push it back in all the way and make sure the agitator shaft is clean and smooth. You may need some sandpaper to get the rust off the splined part of the shaft. When pulling out, try twisting and pulling at the same time. You might have someone else use a block of wood and hammer to tap on the top of the agitator shaft as your pulling it out the bottom. Once you do get it out, make sure you rotate the brake cam drive CCW while pushing back in on the spin tube, I see that it has dropped a bit.
Eric
โ Begin quote from fairbank56;794403
Eric
โ End quote
Thanks so much for all your advice. Husband took pity upon me a bought a new machine.
