Need video help on installing w10116791 kit
My washer is leaking from the seal under the tub. I purchased the kit # w10116791. I’ve got as far as removing the inner tub bolts but tub will not come out. So I’ve removed the whole tub assembly from the washer. I’m going to try and soak the area with penetrating oil and see if that helps. I’ve looked all over internet for video but no luck.
Here is a vid that might help.
http://fast.wistia.net/embed/iframe/shnhemqqcn?controlsVisibleOnLoad=true&plugin[socialbar-v1][buttons]=email-twitter-googlePlus-facebook&version=v1&videoHeight=237&videoWidth=422&volumeControl=true&autoPlay=true
Thanks for your help but the video of the washer was totally different from what I have. I thought I read some where’s a guy left a link to how to get a stuck inner drum apart? I have soaked mine over night and I still can not break it loose.
