Neptune washer
My Neptune washer mah 5500 drains well cycling well only problem is when cycle stops water still pouring into tub. Fabric softener tray has filled with water. I opened washer and water poured out the front door. Can anyone help me identify the problem. Hopeless in holbrook
Hello Ivanr44. It sounds like you will need to order and replace the water valve on the unit. AP4027591
