Washer worked great but needed bearings. Replaced bearings and tested in garage using a Y connector hooked to a cold hose bibb for both hot and cold. Bearing replacement appeared successful and it purred like a kitten. Took it in the house and it won’t run, fills with water and door locks then shuts off after a minute or so, took it back out to garage to work on and test and it ran perfect again having cold hooked up to both. Took back in house and won’t run again! ! Any ideas?
Gosh, I always have an answer even when I don’t know that I am talking about, but in this case I have no idea. Some connection may be loose and that affects it when you move it, but the likelihood it would do it twice is very small.
