Per a recent post, I just replaced the control module on my dishwasher. After installing the new module I still get lights flashing on the panel, but now it’s the "heavy duty" and "normal" cycle lights. It still won’t run. Before it was the "normal" and "cancel’ lights. Here’s the test I ran. Any advice?
Your parts
Parts for Whirlpool KUDP02CRBL2 Dishwasher - AppliancePartsPros.com
To determine if the control or keypad is faulty, do the following test:
Unplug dishwasher or disconnect power Open the dishwasher door. Open console and disconnect the keypad ribbon connection from the control (at P1). Make sure all other connections are made. Put console back together. Do not close the dishwasher door. Plug in dishwasher or reconnect power. Wait 5 seconds. Close dishwasher door. Monitor the control’s response.
-If the control is OK (no longer sees shorts with the keypad unplugged), it will respond by turning on the drain motor for 2 minutes. Check and/or replace the keypad if the control responds OK.
-If the control is not OK (still sees shorts with the keypad unplugged), then the drain motor will NOT respond. If drain motor does not start within 10 seconds, repeat or verify that all steps were followed, and then replace the control.[LEFT][COLOR=#000000]
Read more: http://forum.appliancepartspros.com/dishwasher-repair/536696-kitchenaid-diswasher-panel-lights-blinking.html#ixzz2hR0jkU56
[/COLOR][/LEFT]
