Model: WTW5830SW0, Serial: CT2340448. Washer drips water into drum when the washer is off. I replaced the water inlet valve assembly. Problem still persists which means the new valve assembly is leaking. There’s nothing else in line. Should I try another valve assembly or start checking voltages to the assembly? I would think that the solenoids would have the valves in the closed state with no power applied. Help!
Unplug the washer. If it still drips, replace the inlet valve assembly.
http://www.appliancepartspros.com/whirlpool-water-inlet-valve-3979346-ap3175369.html
Eric
