Newer stove on the fritz HELP PLEASE!
Hello! I am new to the forum and did some searching but did not find anything related to my topic. I have a 4 year old Frigidaire fges3045kfa stove. I started to get an F12 Error code and did my due diligence and found out that it supposedly can only be a bad EOC. I ordered a new EOC and hooked it all up and got the same F12 Error code. Does any one know if the touch pad sensors that are part of the Panel Assembly (they look like white plastic 1 " strips) that plug into the EOC, can this go bad? If it is not the EOC, should I try to replace the panel assembly with these strips from the touch pad? Is there anything else that can cause the F12 error code that just is not in the manuals etc.?
Any assistance or recommendations would be greatly appreciated.
Thanks,
Rob
