NG to LPG
I have lost my manual. I need to know how to covert my range to propane. Kitchen-aid or Sears told me how to do it but I forgot and there service to answer questions. I need to do it before the propane company comes on Monday.
— Begin quote from bg1234;333496
BG,
I’ve attached the basic conversion information, from the service manual, for you.
And a Technical Note for accessing the top burner orifices.
You’ll need to turn off power and gas to the unit and remove from cabinet.
[LEFT][SIZE=3][FONT=Helvetica-Bold][SIZE=3]Pressure Regulator Conversion[/SIZE][/SIZE][/FONT][FONT=Helvetica-Bold][SIZE=3]
[/SIZE][/FONT][SIZE=2][FONT=Helvetica][SIZE=2]Installed in the unit is one of two types of regulators.[/SIZE]
[/SIZE][/FONT][SIZE=2][FONT=Helvetica-Bold][SIZE=2]Converting Regulator Type 1[/SIZE][/SIZE][/FONT][FONT=Helvetica-Bold][SIZE=2]
[/SIZE][/FONT][SIZE=2][FONT=Helvetica][SIZE=2]Push down and turn counterclockwise to remove cap.[/SIZE][/LEFT]
[SIZE=2]Turn cap over and reinstall[/SIZE]
[LEFT][SIZE=2][FONT=Helvetica-Bold][SIZE=2][FONT=Helvetica-Bold][SIZE=2]Converting Regulator Type 2[/SIZE][/SIZE][/FONT][FONT=Helvetica-Bold][SIZE=2]
[/SIZE][/FONT][SIZE=2][FONT=Helvetica][SIZE=2]Remove cap and force plastic plunger from bottom of[/SIZE]
[SIZE=2]cap. Turn plunger over and force back to original[/SIZE]
[SIZE=2]location.[/SIZE][/LEFT]
[/SIZE][/FONT][FONT=Helvetica-Bold][SIZE=2][FONT=Helvetica-Bold][SIZE=2]NOTE:
[/SIZE][/FONT][/SIZE][/FONT]
[LEFT][SIZE=2][FONT=Helvetica][SIZE=2]Plunger must snap into position, and the type of[/SIZE][/SIZE][/FONT][FONT=Helvetica][SIZE=2]
[LEFT][SIZE=2]gas being supplied (NAT or LP) must be visible[/SIZE][/LEFT]
[SIZE=2]on lower side of plunger[/SIZE]
[LEFT][SIZE=2][FONT=Helvetica-Bold][SIZE=2][FONT=Helvetica-Bold][SIZE=2]Converting Regulator Type 3[/SIZE][/SIZE][/FONT][FONT=Helvetica-Bold][SIZE=2]
[/SIZE][/FONT][SIZE=2][FONT=Helvetica][SIZE=2]1. Pop–off plastic dust cover from cap nut (top of[/SIZE]
[SIZE=2]regulator). Remove cap nut (plastic dust cover is[/SIZE]
[SIZE=2]attached to cap nut). Remove plastic dust cover from[/SIZE]
[SIZE=2]cap nut and reinstall on opposite side of cap nut.[/SIZE]
[SIZE=2]2. Reinstall cap nut into regulator. The marking for the[/SIZE]
[SIZE=2]type of gas being supplied (LP or N) must be visible[/SIZE][/LEFT]
[SIZE=2]in top of cap nut. Pop–on plastic dust cover[/SIZE]
[LEFT][SIZE=2][FONT=Helvetica-Bold]Gas Conversion[/FONT][/SIZE][FONT=Helvetica]
[SIZE=2][SIZE=3][FONT=Helvetica-Bold][SIZE=3]Orifice Conversion: Natural Gas to LP Gas[/SIZE][/SIZE][/FONT][/SIZE][SIZE=2][FONT=Helvetica-Bold][SIZE=3]
[/SIZE][/FONT][SIZE=2][FONT=Helvetica][SIZE=2]1. Screw the burner orifice hoods down tight against the[/SIZE]
[SIZE=2]pins. [/SIZE][/LEFT]
[/LEFT]
[/SIZE][/FONT][LEFT][SIZE=2][SIZE=2]Do not over tighten.[/SIZE][/SIZE][SIZE=2]
[LEFT][/SIZE][SIZE=2][FONT=Helvetica][SIZE=2]2. Screw the burner orifice hood down tight against the[/SIZE]
[SIZE=2]valve body. It is important to turn down the hood as[/SIZE]
[SIZE=2]far as possible to ensure complete conversion.[/SIZE]
[/SIZE][/FONT][FONT=Helvetica-Bold][SIZE=2][FONT=Helvetica-Bold][SIZE=2]NOTE: [/LEFT]
[/LEFT]
[LEFT][SIZE=2][FONT=Helvetica][SIZE=2]On units using Eaton Oven Safety Valve, screw[/SIZE][/SIZE][/FONT][FONT=Helvetica][SIZE=2]
[LEFT][SIZE=2]the valve orifice hood down tight against the[/SIZE]
[SIZE=2]valve body. It is important to turn down the hood[/SIZE]
[SIZE=2]as far as possible to ensure complete[/SIZE]
[SIZE=2]conversion.[/SIZE]
[SIZE=2]3. Adjust burner air shutter to the widest opening that[/SIZE]
[SIZE=2]will not cause the flame to lift or blow off the burner[/SIZE][/LEFT]
[SIZE=2]when cold.[/SIZE]
[SIZE=2]Access to Cooktop Burner Orifices[/SIZE]
[SIZE=2]1)Remove the burner grates and caps[/SIZE]
[SIZE=2]2)Remove the burner base nut(24mm)securing the burner[/SIZE]
[SIZE=2]3)Remove the burner[/SIZE]
[SIZE=2]4)Remove the two screws,one on each side of the unit,securing the main top[/SIZE]
[SIZE=2]5)Remove the four 1/4" hex/phillips screw,two on each side,securing the side trim to the body[/SIZE]
[SIZE=2]6)Remove the two screws,one on each side,securing the main top,[/SIZE]
[SIZE=2]when the side trim is removed,two screws will be visible, Remove the furthest most screws from the control panel[/SIZE]
[SIZE=2]7)Remove the main top and set aside. the ignitor wires will need to be[/SIZE]
[SIZE=2]marked and disconnected, if the top is to be removed and set away from[/SIZE]
[SIZE=2]the range [/SIZE]
[SIZE=2]8)Access to the orifice hoods are now available[/SIZE]
[SIZE=2]Turn ofifice hoods down(clockwise) two to two and a half turns[/SIZE]
[SIZE=2]9) reverse procedure to reinstall[/SIZE]
[SIZE=2]We hope you get this in time,[/SIZE]
[SIZE=2]Good Luck,[/SIZE]
[/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/FONT][/SIZE][/SIZE][/FONT][/FONT][/SIZE][/SIZE][/FONT]
[/LEFT]
Yes thank you!!
— Begin quote from bg1234;333731
Yes thank you!!
BG,
Glad we got it to you in time,
Let us know how things went, we’d appreciate it,
Good Luck,
Well it went like this. The building inspector didn’t leave me a blue tag saying I passed. I can’t get in touch with him because government offices are closed today. So the gas company canceled until next week. More peanut butter and jelly.
So updates will begiven after next Tuesday. Unless some one cancels. LOL
— Begin quote from bg1234;334615
BG,
Sorry to hear that,
I was hoping, for you.
We’ll keep an eye out for your update,
:cool: :cool: :cool:
Bumping an old thread. Wanted to say thanks for this. I am trying to go from LP to NG on a Jenn Air JGS8850ADW so I try out these footnotes on accessing the burner orifices. Thank you. I will let you know how it works.
BTW thanks to appliancepartspro for the quick shipment of the new ECU controller (have to send it back - needed control panel instead) and the new control panel as that was what was wrong. Should have read the F1-8 codes clearer here to see that it was teh control panel not the ECU controller.
Mikie
— Begin quote from Joe / APP Team;576504
Mike,
You’re doing fine, 2 to 2 1/2 revolutions won’t make a major difference, you 'll be fine, especially when you fine tune the fuel air mixture, if needed.
The bake and broil orifices are converted in the same manner, use a 1/2 in. open end wrench and adjust the orifice the same, as the top burner orifice.
joe just wanted to say thank you. SI shoudl be doing the change over here in a couple hours when some muscle arrives and we can get this Jenn air upstairs.
Off yto buy a new hose and a F to M copnverter and a 90 degree elbow.
I will get that oven orifice converted too.
The new control panel worked great! Thanks for selling those too me appliancepartspros!!
— Begin quote from blo0omingtonmike;578752
Mike,
Great, Remember to drop us a line when you’re done.
We’ll keep an eye out for your post.
— Begin quote from Joe / APP Team;580962
Mike,
Everything worked great. Got the stove installed Sunday. May move my gas line a bit as it hits the back of the range and I cannot put it as far back as I could.
Also I need to check that circuit as I turned on convection and the oven light and I tripped a breaker a bit after the fan started after warm up. May be a weak breaker. I have not had that large a load on that circuit before.
Any good suggestions for hiding the back gap where the stove does not meet the wall flush?
— Begin quote from blo0omingtonmike;581195
Mike,
Glad things are coming along well.
Hopefully it’s just a weak breaker or connection, there is a possibility that there could be a pinched wire from the cooling fan, and you may want to remove the back panel and check it first.
There was at one time an insert trim panel to fill in between the counter top and wall. 7706p009-60 is a part number, (if it’s still available) and may work for you.
On the AppliancePartsPros.com parts page for the Maytag MDE4000AYW dryer:
https://www.appliancepartspros.com/03-control-panel-parts-for-maytag-mde4000ayw.html
There are two separate parts listed for Item # 7: Timer
AP6007988 - WP33002676
AP6007935 - WP33001730
Which of these two parts is the correct replacement for my Dryer Timer?
Below is a picture of my Dryer Timer’s Data Plate.
Dryer Data Plate
