Agitator barely moves however it does go into agitate mode as soon as water level selected is obtained water valve cuts off and a rumbling, grinding sounds begins removed plastic cap on large pulley underneath looks fine didn’t want to go further not knowing what to look for, drive belt looks fine. Is there a spline to chek on agitator, ratcheting motion on upper half of agitator is working fine its lower half not working. Any suggestions? THANKS!
I would start by taking off the agitator (it is held down by a bolt under the cap). I am guessing you will find the problem with worn splines on the bottom half, but you will have to look at it to be certain.
If you need to see the lay of the land, click on your model number and you will be taken to exploded views of your machine.
