No dispenser power
There is no power to the fountain at all. Hope someone has seen this problem before, thanks in advance.
I was wondering if you checked the freezer liner switch. It must be a 2 position switch where there might be a possibility of the switch being bad, and the dispenser thinks the door is open, and it won’t work. Therefor you would not get a volt reading there. That is my only thought. Of course I can’t tell by the breakdown what type of door switch it is. Tom http://www.applianceeducator.com
Good Luck!! Tom
Just as you suspected, the door switch was bad, switch tested ok with ohm meter, but the dispenser worked when I jumpered the switch! Thanks again.
