Hello,
Just got this dryer off Craigslist a few months back and now it’s not heating.
I tested the Thermal Fuse, Heating Element, High Limit Thermostat, and Cycling Thermostat for continuity and they are all good. Got continuity on outer pins of Cycling thermostat but not smaller inner ones, but I did get a reading of 5K Ohms.
So what do I check for now? We really need this dryer working asap. Not sure what else to check or what could be the issue.
Any help or suggestions?
Thank You
EDIT
Ok I plugged it in and tested the terminals where the plug connects to inside the dryer. With my probe on the ground wire in the center I tested one side and got 120-121V but when I did the other side/wire I only got about 10V. I should be getting 120V there shouldn’t I even with Dryer off, considering the plug is running straight to it.
So I take it a breaker is out? That sucks cause we use plug fuses and none of them are labeled and none looked bad. lol. Well guess I’ll look them over again.
