I have power through everything,put in new 4-way selector switch.I am lost,please help!
Well sorry you are having problems, and we may be able to help but we need some more information.
What was the dryer problem before you replaced the "4 way switch"?
Can you tell us exactly what part you replaced? Reference the parts diagram which you can find by clicking on your model number.
Can you list each component you tested with an electrical meter and what the results were?
Does the timer advance with no heat, or does it just stay put. I am assuming the drum turns and the blower blows out cold air but there is just no heating. Is this correct?
Are the symptons constant in all drying cycles.
Let’s see what you might have when we have this info.
