Ignitor Glows, Checked The Ohm Reading ,was Less Than 100 Ohms,checked Continouity On Flame Sensor And Tested Ok,doesn’t Seem To Be Allowing Any Gas Into The Burner
— Begin quote from dtallio;155129
If the ignitor glows and then fades away without ignition, the usual culprit are the coils on the gas valve. See below.
[part]AP3094251[/part]
