no heat
GE PROFILE HARMONY ,MODEL NUMBER DPGT750ECWW
There is no heat at all from the heater assembly…Blower and every thing else works.There is the correct 240 volts at the wall plug and at the terminal block on dryer.I took out the heater assembly and checked for continuity in elements and it is okay.Also checked for open in the 2 thermostats on the assembly,they are okay.I need a wire diagram schematic to try and trace down the problem???
