no ice, no water, from freezer door dispenser. appears that there is no power to door (no lights at all). checked electric connecter on upper door hinge-looks ok. any suggestions on what to do?
paul
paul
Hi, Paul.
Please check the freezer door switch. Power to the dispenser control is supplied through that switch. You should read continuity between C and NO when switch is pushed in.
The light switch 241547901
Here are the breakdown diagrams and http://www.appliancepartspros.com/cabinet-parts-for-frigidaire-glhs68eeb4.html
Post the results.
Simon.
any way to remove switch from freezer side or do i have to go in from the back of the freezer wall? in photo it looks like there is a "catch", dont know to get to it.
paul
Hi.
Yes, there is the catch on one side of the switch.Use a putty knife and flat screwdriver to pop it out.
Unplug the fridge while doing it.
Simon.
— Begin quote from Simon / APP Team;794625
Hi.
Simon.
thanks
i got the switch out, and there is continuity between C and NO, when i push the switch in. what else do i need to check?
paul
i got the part you suggested, any hints on disassembling the dispenser without breaking anything. are there screws under the button cover or does the cover pop off (catches?), etc
paul
Hi.
If you pull out the drip tray you’ll see screws holding the frame.
Simon.
— Begin quote from Simon / APP Team;799241
Hi.
Simon.
I put the power board in this morning, still no power at all. ichecked connections, any thoughts?
paul
Hi.
Check if you are getting 120VAC to the power board between Red/Blk and LtBlu?
If you do then check the harness ribbon and replace the switch control board
You can return the power board for full refund.
Post the results.
Simon.
— Begin quote from Simon / APP Team;799395
Hi.
[part]241708306[/part]
Post the results.
Simon.
thanks for your help. I checked the 120vac and the harness ribbon continuity. all ok. i noticed some substance on the harness ribbon connector and cleaned it. when i reassembled everything with the old board iit all worked.
thanks again
paul
You are welcome.
simon.
