Suspect control Panel on front of icemaker/water dispenser is faulty. When touchpad is pushed to select ice/water…green indicator light goes on/off but will not dispense either ice or water
— Begin quote from savery;121209
Problem presently is intermittent
I’m having the same issue, except I’m not seeing any lights. Is it the control panel bad?
GE Refrig Part # PSS26MGPA
I have ordered the control panel and will see what happens
changing control panel did not help…any ideas from anyone???
