no ice
Ice maker in my side by side just quit working. Manufacturer P1190701WL. It doesn’t make noises. The hoses don’t have water in them. I shut the delivery water line and flushed, plenty of water there. Reconnected line. Could it be a fuse or is it the actual ice maker not sending signal to water valve to deliver water? or is it the water valve? I removed the cover to the ice maker, but this model appears to not give you access to any connections to test. What do I do? Help, I fix other appliances, but don’t know how to trouble-shoot ice-maker. :eek: Jere
