No Ice
WATER DISPINCES INTO GLASS ,BUT NO WATER GOES INTO ICE MAKER:o
The first thing I would check is the water feeding tube into the ice maker for ice inside.
If it’s frozen, you can use a hair dryer to defrost it.
In that case the water inlet valve has to be replaced.
  • The part number for the water inlet valve is AP4298908
