no lights on front control panel- duet washer
I replaced the door lock washer worked fine. Then I did a load of laundry went to do another load the control panel stoped working. The only light that works is the lock unlock. I replace the door lock again and the ccu same problem. Help
Take some non-residue contact cleaner and spray all the connectors while plugging them in, might fix it. Also, look for loose wires at the connectors.
