I’ve got a GE Hydrowave GTWN4950L0WS that’s only about 4 years old. It stopped working abut two weeks ago. When you push the start button, the fill light blinks, but nothing happens. No water flows and nothing happens. The fill light keeps blinking and there is a beep about every 20sec or so.
Performing the field service mode for error codes, the panel indicated a bad thermistor code. I ordered an ATC Temp Control Probe and replaced it. The thermistor code disappeared and there were no other field service codes. So I should be good, but NO… still not running. Just the fill light blinking and a beep every 20sec. So I popped the cover to get inside.
[LIST]
*]I checked out the magnetic door switch. It checks out good, showing continuity with the door closed and pen circuit with the door opened.
*]I checked the fuse by putting my multimeter on the neutral plug post and the motor’s neutral pin and got good continuity.
*]I looked to the motor to find any error codes blinking on the motor LED… No error codes blinking, no status codes at all, and no LED blinking at all.
[/LIST]
Do I have a dead motor or dead main board? I can’t imagine the motor is the issue because it never even begins filling… there’s just the blinking light on the panel and occasional beep. I don’t think it could be a fuse either because people with fuse problems still at least get water filling - just no spinning or agitating.
