No Oven nor Display
We have a problem where, even when the oven is not in use the display goes away and the oven will not work. It will come back on all by itself at any given time and the oven will work perfectly. I put it in the cleaning mode 20 mins ago and it is still on. Please help !!
Most likely the problem with you oven is a bad electronic oven control (aka EOC) which has to be replaced.
my oven glass rests on the outside of the door with no side or bottom trim also. I removed the glass to clean behind it by removing the two screws at the top of the door and the two screws holding the clips on at the bottom of the door. The glass was simple to remove, clean, and replace once i removed the door from the oven. Mine is a kitchenaid and may be different to remove than yours but its worth looking to see i guess.
Whirlpool makes Kitchen Aide, so they are very similar. They are pretty easy. I recommend using a padded surface.
Nat
