Ran self cleaning cycle, the oven did not finish and powered down. I can’t get power to the oven but the gas cooktop is working. I have checked the outlet that the oven is plugged into and all is fine.
Many threads have pointed to a thermistor/thermostat as the culprit for this issue.
If anyone can suggest a method so that I can get to the latch release and open the door. I have tried many paths to get the front panel off and none have been successful. Any suggestions would be most appreciated.
