no power to fill valve
I am not getting water in the dishwasher. I changed the fill valve, I am getting water to the valve, but no power. I changed the timer as well, but no voltage to the fill valve. The pump does run, so the door switch is working. I also checked the overflow switch, and that ohms out fine. Anyone got any ideas. The only thing left is to change the control switches.
Remove the inner door panel and check the pushbutton switches on the left side. Most likely one of them is broken or burned out.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=209309
The Switch Was Bad For The Heated Dry On/off Option. Thankyou So Much For Your Help!!!
You are welcome. I’m glad you were able to fix it. Thank you for the feed back.
