Hi, my name is Jay. Ihave a kitchenaid kssc42qks00. While checking my ice maker I accidentlyshorted the wrong terminals to start the ice maker cycle. (I previouslydiscovered an always open thermostat in ice maker). Now I have no power to icemaker. Thermal fuse is good, there is no power before thermal fuse. The waterdispenser and ice dispenser work and the lights all work. Everything else worksgreat. I check the wiring diagram that came with the frig and it looks likepower comes from terminal #5 (LB/BL) on the control board but that also powersthe water and ice dispenser, they work so I’m thinking the electronic controlis OK. Any help would be greatly appreciated
the wiring diagram that came with the frig is incorrect. I found the correct one online from whirlpool. the problem was on the main control board. I could see where the circuit was fried (open circuit) on the printed circuit board.(see attachment) I was able to solder a wire over it to repair the open circuit.
