No Pressure At Sprayarms, It Squirts Out In A Solid Stream About 2 Inches, But Not Enough To Move The Sprayarm. — I Removed Impellers, Both Wash And Drain, They Appear Ok, ---- Replaced Both Upper And Lower Bushings On The Sprayarm, Still No Pressure — Lots Of Water Movement Around The Filter, I’m Losing Pressure Someplace, Maybe A Gasket/seal… When I Reassembled The Unit I Did Not Replace The Gaskets/seals, But The Problem Begin Before I Disassembled It — Did It Blow A Gasket/seal Someplace ??
DCANDY said:
No Pressure At Sprayarms, It Squirts Out In A Solid Stream About 2 Inches, But Not Enough To Move The Sprayarm. — I Removed Impellers, Both Wash And Drain, They Appear Ok, ---- Replaced Both Upper And Lower Bushings On The Sprayarm, Still No Pressure — Lots Of Water Movement Around The Filter, I’m Losing Pressure Someplace, Maybe A Gasket/seal… When I Reassembled The Unit I Did Not Replace The Gaskets/seals, But The Problem Begin Before I Disassembled It — Did It Blow A Gasket/seal Someplace ?? TRIED ADDING MORE WATER – DID NOT WORK, HELP !!
