No spin and drain.
My washer doesn’t spin nor drains but the pulley wheel and belt are fine. The agitator also is working. From what I could glean from the internet, I would say that my pump is out. What would you think?
[SIZE=3]The pump doesn’t give a lot of trouble but it will often get clogged. Remove the water from the tub and remove the hose from the pump. Once done check to see if there is anything clogging the pump if so, remove the obstruction. Hope this helps![/SIZE]
[SIZE=3][/SIZE]
http://www.appliance-repair-it.com/clothes-washer-repair.html#Top
