Hello,
No water is going into the dishwasher when i turn it on. there is water going thru the pipes, I replaced the inlet valve and still nothing. what could it be?
thank you
Hello,
thank you
Check the overflow switch.
Left hand side behind the kick plate.
May even be that the float is stuck in the up position.
Hi Redman,
what exatly am i looking for. what does the switch look like.
I dont see it on the diswasher and i dont see it in the parts diagram.
