Hello’
I need advice on a stack washer/dryer when in spin cycle , it sounds like an aircraft winding up for take -off. only started six months ago, we don,t use but about 1 time aweek…I’m thinking either transmission is low on grease or maybe the spin bearing is bad or dry, i don’t know if its a bushing or sealed bearing, but i do needadvice on how to get to it and check it.
thanks
Hi,
You maybe correct that it’s the bearings that you are hearing, but I always check the simple things first.
It could be something as simple as something caught in the water pump.
If you have not seen it already here is the service manual for your washer.
