Non working display dispencer panel GE Monogram
How do you replace this panel? How do you take it out?
[AP4368052](http://www.appliancepartspros.com/partsearch/ctrfs.aspx?part_id=4368052&&model_id=5200698&diagram_id=23826724"]Display touch disp blk[/URL]
Part Number: [URL="http://www.appliancepartspros.com/partsearch/ctrfs.aspx?part_id=4368052&&model_id=5200698&diagram_id=23826724) made by GE
Use a screwdriver to unlock the tubs at the bottom of the control panel. Slide the bottom out and down.
— Begin quote from Gene;100091
Hello Gene,
The blocking it. I have [SIZE=4]Stainless Steel side by side model and the follwing is blocking it.[/SIZE]
[SIZE=4][/SIZE]
[AP3187757](http://www.appliancepartspros.com/partsearch/ctrfs.aspx?part_id=3187757&&model_id=5200698&diagram_id=23826724"]Collar kit- black[/URL]
Part Number: [URL="http://www.appliancepartspros.com/partsearch/ctrfs.aspx?part_id=3187757&&model_id=5200698&diagram_id=23826724) made by GE
Please help.
Can I call you?
Thanks,
Avi.
480-252-5999
Avi,
I have the same problem with my refrigerator. Were you ever able to get the touch panel out by yourself? Do I need to disassemble the door or can the panel come out from the front. It appears that the Stainless Steel is blocking the touch panel from coming out.
