Works fine until the last short rinse and final rinse. Local repair shop said to replace the timer which I did. Same results. Water input working well. Checked continuity on coil Ok. Wanted to check sensor to see if return on water valve solenoid missing but could not lovate sensor. Need help Thank you
Related topics
dishwasher water after any cycle | 4 | 11254 | January 7, 2014 | |
To repair or not to repair? | 1 | 1200 | April 6, 2010 | |
Timer issue? | 2 | 2138 | September 23, 2009 | |
ed | 0 | 969 | February 27, 2009 | |
timer cycles over and over | 1 | 921 | March 3, 2014 |
